Throttle Valve Control part (J338): Fault in basic settings
Old Jan 24, 2007 | 12:40 PM
martini_zupa's Avatar
Default Throttle Valve Control part (J338): Fault in basic settings
Hi!
Got diag cable, VAG gives me this error code on A6 C5:
17967 - Throttle Valve Control part (J338): Fault in basic settings
P1559 - 35-00 - -
Now, the "original" question - how to correct this? As I understand TVC reads accelerator position and passes it's position to AT, so AT could correctly adjust acceleration etc... Actually my automatic gearbox could be more precise, there is a gap in acceleration at some point.
Thanks!
Old Jan 25, 2007 | 01:35 AM
foorausfoora's Avatar
Default RE: Throttle Valve Control part (J338): Fault in basic settings
you can easily get this fixed at an augi dealer for $95.00. you will not be able to fix this problem without the proper machine i believe only audi has. the car doesnt idle correct right? and it doesnt have the regular power?
vtraudt
Mar 1, 2011 12:47 PM
ongrade
Feb 1, 2011 06:38 PM
a4kt
Sep 30, 2005 09:39 PM
