Tire damage
It depends where you drive. I hit a small pot-hole in Detroit with my 17" rims and Pirellis and it put in hole in the tire that was not repairable. Fortunately the rim was undamaged.
I also had an 18" Cooper tire go mysteriously flat - it just started melting. Rim undamaged. Later took it on a 2500 mile vacation and when I returned they were so badly worn on the inside (some cord showing) I had to replace them. I talked Discount Tire into replacing them with Conti's and have had only on flat since then - the only time my wife was driving and again in Detroit. No damage to the rim and I had coverage on the tire.
If you're running 16" rims I would not be concerned. If you are running 17-18" in a city where there is a lot of construction or rough pavement, it's a consideration. However, how many flats before it costs more than $600. My history spans from 5/2005 and 81k miles.
There are also hairline cracks that can appear in rims which are a nightmare to fix.
It really depends on where you drive and how bad the roads are, as everyone has already mentioned.
If it 600 for 3 years, that's 200 a year. Which is one new performance tire a year. Problem is, you have a quattro so you will probably have to change more than one so that the rolling diameter is close enough. It's a close call on value for money, but then there is piece of mind too...
Bklynrx7
12-30-2009 01:27 AM
sirfalconx
11-22-2007 09:27 AM
