Towing a Quattro
Old Jan 17, 2011 | 08:58 PM
Jjedlicka's Avatar
Default Towing a Quattro
I need to tow my car into a garage to get the power steering pump replaced. I don't want to drive it in, in case metal shaving get into the rack. Don't really want to replace that either. I have a buddy with a car dolly; I've been looking online and everyone tells me not to do this as it will mess up my rear diff. I don't understand how that if the front wheels are lifting off the ground and the tranny is in neutral, how will that damage the rear diff?
Old Jan 17, 2011 | 11:16 PM
niknak's Avatar
Audi recommends using a flatbed for all quattro vehicles
Old Jan 18, 2011 | 08:04 AM
UberTeile's Avatar
I think the center diff can be damaged if you tow a Quattro on only 1 axle...the flatbed is your friend.
UberTeile
Old Jan 18, 2011 | 10:31 PM
Jackmup's Avatar
You can only do that if you pull the rear drive shaft.
Just rent a u-haul trailer not a dolley
In general you never tow any car with the drive wheels spinning if it has an automatic. Because the pump is not pumping fluid and cooling it. So basically you would be spinning the transmission without lubrication.
You must pull the drive shaft before you do so.
This drive shaft ain't no GM, 4 bolts and it's out special either.
I third the flat bed, support your local economy!!!
imaudi5000
B7 Models
Mar 18, 2012 10:50 PM
rdlmitedu
B7 Models
9
May 27, 2008 02:11 PM
xerexb
May 20, 2007 11:35 AM
turtlehead
Oct 14, 2005 02:46 PM
audiboy1618
Jan 3, 2005 08:53 PM
