tranny fliud
Old Dec 19, 2008 | 06:28 PM
Kevin's Avatar
I replaced the tranny and differential fluid at 40k miles in my 05 4.2. But I am a little nuts on maintenance.
Old Dec 22, 2008 | 10:35 AM
nemohm's Avatar
"I was living under the impression that an automatic transmission has a "multi-disk clutch pack" (I called it "kit") - 2 halves, that is applied via piston action, causing the output shaft to spin at the same speed as the input shaft, hence allowing shifting through the gears. If the clutches are worn out, the shitfing is affected.
But that's just in theory. You guys surely have a more extensive knowledge related to the automatic Audis. I just learn as I go, by discovering things about this car."
Let's get an end to the clutch confusion.
The clutch you are referring to is the notorious "captive clutch" ! - locks up the TC - failure leads to TC replacement - there is an Audi TSB.
More details here:
http://www.transmissiondigest.com/te.../200512TCT.htm
I doubt you have that the dreadful application.
Old Dec 22, 2008 | 12:50 PM
chefro's Avatar
No problem, I got over the confusion some days back, thanks to Axel_NY's tranny diagram.
I do have a clutch, and the tranny does have a filter as the one posted on the previous page.
Thanks, nevertheless.
Old Jan 15, 2009 | 10:52 PM
sixxlee's Avatar
hey guys i have question about changing my transmission fluid. I heard you're not suppose to change it with european cars but we all no that eventually u have to. I have a 2001 A6 2.7t 5sp tip. any thoughts would help. also i have about 101000 miles on it.
Old Jan 16, 2009 | 02:54 PM
nemohm's Avatar
Search the forum=> there is a plenty of info here!
Old Jan 16, 2009 | 09:13 PM
aurfawce's Avatar
I didn't realize the Audi A6 had a problem shifting in first gear.. I thought my tranny was slipping because recently even when I let the car warm up enough I feel outta first gear the shift is quite hard. It seems the rest of the gears are fine, but I was planning on changing the tranny fluid to Redline.
Old Jan 17, 2009 | 11:14 AM
99A6Quattro's Avatar
What would it cost to replace tranny fluid and filter?
Old Jan 17, 2009 | 01:02 PM
  #18
chefro's Avatar
Dealership - Have no idea; you can call them and ask.
DIY:
* Filter Gasket/Seal Ring ......... $ 1.25
* Filter KIT (including Filter + Pan Gasket) ---- $ 25.70
* Final Drive Oil Seal; Front/Rear Left/Right; 45x60x8mm; Differential Output Seal
For models with manual transmission. (4 per car)...... $ 2.49/piece
* Transmission Mount (IF YOU NEED - 2 per car) .... $ 55.74/piece
+ ATF Fluid (5/6 quarts?) - $ 50- 60.
Whomever has the same model as yours, could tell you better the exact ammount.
jrocc
Mar 18, 2013 09:17 PM
Nemick
Sep 11, 2012 05:33 PM
luxuryimports1
Jul 4, 2009 10:56 PM
jimmyt853
Jul 6, 2007 07:41 AM
