Transmission Fluid Filler location
If you're going to DIY, make sure the car is completely level, and warm the fluid up before draining (I ran the engine to idle temp and let it cool for about 10 minutes before I drained). Also, I don't know what you're using for a pump, but I STRONGLY advise against the auto store pumps that attach directly to the bottle of transmission fluid. It's not that they don't work (mine did), it's just that it's a complete and total pain in the rear end. If I had to do it again, I would have gotten a high output manual pump with a large reservoir, poured all of my fluid into it, and pumped it that way. Less messy, faster, and frustration free.
Not sure what everyone on the board thinks of Blauparts, but I followed these instructions and everything worked out pretty well for me.
http://www.blauparts.com/audi/audi_f...on_fluid.shtml
Note, however, that I pretty much flushed my system of transmission fluid, not sure if you're planning on doing that or not.
Agreed. I just finished refilling my car with transmission fluid, and let me tell you, I'd never do it again. ............. I have no idea what possessed them to go away from the standard "side-of-pan hex bolt" (like 99% of all filler plugs), but it couldn't have been a good reason :P. .............
