transmission relays?
Old 10-01-2008, 07:45 PM
Default transmission relays?
Are there relays associated with the transmission? Is there a relay for the TCM or just a fuse? I am told i might have a sticking relay but i don't see one in the bentley book besides the "selector lever light relay".
Old 10-03-2008, 12:50 AM
bump...nobody?
Old 10-04-2008, 12:34 PM
Jeffla's Avatar
I think they are talking about sticky solenoids not relays. You have many solenoids in your transmission.
"A transmission solenoid is an electro-hydraulic valve that controls fluid flow into and throughout an automatic transmission. Solenoids can be normally open or normally closed. They operate via a voltage or current supplied via the transmission computer or controller. Transmission solenoids are usually installed in a transmission valve body, Transmission Control Unit, or transmission control module." http://en.wikipedia.org/wiki/Transmission_Solenoid
What are the problems you are experiencing?
Old 10-04-2008, 01:24 PM
The problem i am having is a transmission fault p1750 i think which says power supply low voltage and everything works fine but all gears are lit up so i can't see which gear i'm in. I describe it in another thread if you searched for that error code, but basically every time i start my car it comes up, if i clear it while driving it stays away until restart. Once in awhile the fault will go away on a start. The reason someone suggested the sticking relay was i changed the fuel filter and when it took a few extra turns to prime the engine the fault didn't come up, but maybe it was just a coincidence. No one i've talked to (every local shop and online here) has had much of a suggestion for this fault.
Old 10-05-2008, 12:06 AM
Jeffla's Avatar
BMW
P1750 Secondary Pressure Solenoid Circuit Range/Performance
AUDI
P1750 Power Supply Voltage Low Voltage
MB
P1750 Electronic Gear Selector Module: Very low control unit supply
voltage
What does the dealer have to say?
Ozzy S
05-09-2013 09:29 PM
AndyAudi16
05-22-2010 08:11 AM
CLX
01-20-2008 07:05 AM
kbuff97A4
10-01-2006 05:32 PM
thintzen
09-20-2005 04:23 AM
Quick Reply: transmission relays?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
