transmission sensor >>>
Old Aug 20, 2012 | 07:22 PM
cataloni's Avatar
Exclamation transmission sensor >>>
I have Audi A6 2004.I have a problem in the transmission, which is that the car is vibrating when I begin to move and continue every time, and sometimes stop vibration after turning off the car and running again. They told me that the problem is in the transmission sensor .
[IMG][/IMG]
Old Aug 21, 2012 | 02:59 AM
cataloni's Avatar
Smile
help please
Old Aug 21, 2012 | 10:37 AM
z28pete's Avatar
There are many sensors in a transmission, some external and some internal. In most transmissions the vibration is an indication that the clutches are slipping and grabbing. This could be the result of dirty transmission fluid (I know, Audi sez the fluid is good for a lifetime, but that is plain BS), bad shift solenoids, low pressure, etc. The pictures you show could be anything, where did the part come from. Your best bet is to go to reputable transmission shop that specializes in German cars and have them fix the problem before more damage takes place.
If your car uses a CVT transmission, good luck.
Old Aug 21, 2012 | 12:01 PM
cataloni's Avatar
Smile
Thank you for your information, i took the car to transmission shop they open the transmission it self and they told me that the part i show you in the picture is the one which causing the vibration you have i your transmission. do you think they are right or is there any solution.
note: we don't have perfect transmission shop.
thank you again
NorthFork
Jul 6, 2015 04:49 PM
Mark(A6-A4)Ct
Mar 22, 2013 01:31 PM
Staudi911
Dec 6, 2011 08:57 PM
rl-1964
Sep 14, 2009 06:57 PM
no1imit2k7
Mar 2, 2009 11:16 AM
