universal 02 sensor?
I found these online. http://oxygengeek.com/item.wws?sku=S...tid=oxygengeek
Has anyone ever used these before? If so how hard was install? Are you able to use these sensors for thefront and rear?
RE: universal 02 sensor?
well i cant see the oxygen censor but i have 2 universal ones installed in front of the catalyctyics
its pretty simple alll u need is some wire cutters and the oxygen censors should come with some connecters all u do is cut the wire for like 1/4 or so and connect them to the old set you will have to cut the old one and use the half that is connected to the car
We used a universal one in out 325 and after getting the connections sealed well we have had no problems. At first we didn't get it water tight and they were throwing codes.
Jeff
Jeff
