Vag Com readout. Need help with CEL
VCDS-Lite Version: Release 1.0
Friday, 05 November 2010, 16:21:10:0 Chassis Type: 4B - Audi A6 C5 Scan: 01,02,03,06,08,15,16,17,18,34,35,36,37,45,55,56,57 ,65,67,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.LBL Controller: 4B0 907 551 K Component: 2.7l V6/5VT G 0005 Coding: 06612 Shop #: WSC 40205 5 Faults Found: 17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl. P1347 - 35-00 - - 16687 - Cylinder 3: Misfire Detected P0303 - 35-00 - - 16691 - Cylinder 7: Misfire Detected P0307 - 35-00 - - 16696 - Cylinder 12: Misfire Detected P0312 - 35-00 - - 16698 - Misfire(s) Detected; Single (unspecified) Cylinder P0314 - 35-00 - - Readiness: 0000 0100 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Controller: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Coding: 0273004284 Shop #: BB 24334 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY1.LBL Controller: 4B0 820 043 L Component: A6-Klimavollautomat D64 Coding: 00160 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI7.LBL Controller: 4B0 959 655 F Component: Airbag Front+Kopf 1002 Coding: 00406 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4B0-907-487.LBL Controller: 4B0 907 487 Component: E Lenkrad Elektronik D03 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.LBL Controller: 4B0 920 980 M Component: C5-KOMBIINSTR. VDO D10 Coding: 02264 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.LBL Controller: 4B0 962 258 J Component: Central Lock/Alarm D33 Coding: 15981 Shop #: WSC 30011 11 Faults Found: 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01575 - Control Switched Off 35-00 - - 01380 - Alarm triggered by Anti-Theft Sensor; Rear Left 35-00 - - 01379 - Interior Monitor Switch (E183) 35-00 - - 01380 - Alarm triggered by Anti-Theft Sensor; Rear Left 35-00 - - 00970 - Unknown Error Code 09-10 - Adaptation Limit Surpassed - Intermittent 00974 - Switch for Heated Windshield (E180) 09-10 - Adaptation Limit Surpassed - Intermittent 01595 - Tire Pressure Control Switch (E226) 35-00 - - 01597 - Drive Battery Pre-Charge Circuit 35-00 - - 01613 - Relay for Fuel-Cooling Pump (J445) 29-00 - Short to Ground 01615 - Tank Door Remote Unlocking Switch (E204) 29-00 - Short to Ground ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Controller: 4B0 959 760 A Component: Sitzmemory D05 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: None Controller: 4B0 951 178 A Component: Innenraumueberw. D04 Coding: 00101 Shop #: WSC 02325 2 Faults Found: 01349 - Alarm via Theft Warning System; Front 35-00 - - 01353 - Wire for Clock/Pulse Signal; Rear at 5V 35-00 - - ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL Controller: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00006 Shop #: WSC 02325 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.LBL Controller: 4B0 035 195 A Component: Radio D00 Coding: 00117 Shop #: WSC 02325 No fault code found. End -------------------------------------------------------------------------------------------------- |
Did you save this then reset it to see what comes back on?
y bumping an old thread?
