Warmup/Cool Down thoughts
Old Dec 7, 2007 | 01:37 PM
Sirn's Avatar
Default RE: Warmup/Cool Down thoughts
Do you have a link to the Power Gasket?
Old Dec 7, 2007 | 04:40 PM
nemohm's Avatar
What are " turbo timers"?
What oil temperature one could reach the most?
Old Dec 7, 2007 | 05:26 PM
nemohm's Avatar
What could be good turbo timer for 2.7T?
Does it go along with the immobilizer?
Old Dec 7, 2007 | 05:50 PM
Four Ring Circus's Avatar
SoCal Crew Member
ORIGINAL: Retard Riot 686
I always warm up my car for atleast 10 min when the temp is below 40 degrees. I hear people do cool them down by ideling after a cruise too havent done it myself might start tho. As for anytime driving i have a 99 A6 and it idles a lil above 1 RPM for about 3-4 min then settles to under 1 RPM Its like it "chokes" or idles high so the engine warms up does anyone elses do this is it normal?
Hey Retard,
I hope when you say you warm up for 10 minutes, you are driving around. The owner's manual specifies not to warm up while parked. It goes so far as to say you shouldn't start up your car until you are ready to leave. I'm not sure if most people here know this, but I'm telling you it is right in the manual.
Old Dec 9, 2007 | 04:03 PM
ppgoal's Avatar
I live in cold Michigan (but keep the car garaged overnight). I only let it idle a couple minutes before driving off, but I definitely avoid any hard acceleration for the first 5 miles or so. That's more than enough to get the temp gauge centered but not usually enough to warm the oil to 175o. It's about 10 miles from the interstate to my house, which gives the car plenty of time to cool down after running a couple hundred miles at high speed.
Old Dec 10, 2007 | 11:23 AM
Teutonic2.7T's Avatar
ORIGINAL: Four Ring Circus
Hey Retard,
4 ring, i've read this in my VW manual too... frankly, i believe that its part of their social responsibility to tell drivers not to warm up their cars before they drive... for environmental reasons.
http://www.wcr.ab.ca/news/2002/0128/warmitup012802.shtml
http://www.oeconline.org/livinggreen/onthego/wintertip
Notice all the pretty flower asterisks in your manual....those are green ideas.
Old Dec 10, 2007 | 11:36 AM
SoCal Crew Member
That makes sense. Thanks for the info Teutonic.
Old Dec 10, 2007 | 01:14 PM
  #18
nemohm's Avatar
Generaly, the warm up period splits to two parts:
- providing oil gets to all over the engine
- the temperature increase for reduced fuel supply
Usually I idle till first turbo roar is over.
At low temperatures - - 20C/0F I let it run longer.
The engine noise is the major indication for me.
What is the highest oil temperature one could reach?
I’ve not gone beyond 90C/190F, usually 70-80C/160F-170F As I’m with Trip it would be hard to go beyond 3k rpm on the flats within the speed limits.
Teutonic, Aren’t you by any chance in Alberta
Old Dec 10, 2007 | 03:04 PM
  #19
nope, nyc.
Old Dec 11, 2007 | 10:38 AM
  #20
maxxstl's Avatar
Member
My car while hardly move if i jump in it and try an drive it without any warming up, acts as if it is struggling to move. Let it set for 3-4 minutes and it gets its legs.??????????
joelhe
Jan 26, 2013 10:53 AM
what?
Sep 28, 2007 10:29 PM
GL8386
Sep 20, 2007 12:30 PM
jigx7
Jul 20, 2007 02:29 AM
Phaedrus44
Jan 1, 2007 06:53 PM
