WARNING SIGNAL
Old Mar 23, 2008 | 12:08 AM
  #21
formulagigi's Avatar
Default RE: WARNING SIGNAL
looks like you need a coil pack on cyl 5
Old Mar 23, 2008 | 02:23 PM
  #22
GDET09's Avatar
Yea I was reading about someone with the same problem. What exactly does the coil pack do? Any ideas how much?
Old Mar 23, 2008 | 03:59 PM
  #23
mustang196718's Avatar
ORIGINAL: GDET09
here, $58.99 from autohauz: https://www.autohausaz.com/search/pr...gnition%20Coil
the coil packs receive a signal from the ECU telling the coil pack when to discharge spark to the plug. works just like the old cap and rotor distributors, but all computer controlled now instead of running off a gear on the front of the crankshaft, and instead of 1 coil controlling all the spark plugs, now each plug has their own dedicated coil. it's a cheap fix, just replace it and it should take care of your misfire. nice thing about computer controlled is that now spark can be advanced and retarded without having to get out and manually change anything.
Old Mar 24, 2008 | 12:16 AM
  #24
GDET09's Avatar
Thanks for that Mustang . I actually went over the whole engine the other day to see if there was anything loose such as pipes. I actually always heard a hissing sound above the right side of the engine. (under top right cover; 2.7t) I found a hole and taped it up. I still have to get some appropriate tape such as electrical but the CEL seems to have gone away after today. I will be getting to scanned again tomorrow and let you know what I get.
Old Mar 25, 2008 | 06:24 PM
  #25
GDET09's Avatar
CEL went away. Got it rescanned and same codes are there though. So I guess Ill start by getting the misfire fixed.
Old Apr 7, 2008 | 12:13 AM
  #26
GDET09's Avatar
Cleaned and switched the coilpacks. The code went away
danbee
B8 Models
Aug 27, 2011 03:06 PM
tims_S6
Dec 30, 2009 06:41 PM
mrdb85
Aug 14, 2007 11:11 PM
mustang196718
Jul 9, 2007 07:08 PM
ianwhite101
Jul 30, 2006 02:42 PM
