washer fluid container problems
hi everybody
my washer fluid container is licking , somebody can tell me if is posible to take out this and to fix it Wich is the better way to fix it: with superglue, silicon, or anything else best regards |
RE: washer fluid container problems
i would take off the driver side tire, then take off the wheel well liner so you can see the container and then try to find the leak. The leak may be on one of the washer pumps (headlight or windshield), so look around. I would also try using silicone once you find the leak. Or, you can order a new washer container online. but i would try to fix it first, rather than spend 100+ on a new container. oh and if you live in a cold place, use appropriate washer fluid so it doesnt crack and mess you up in the furure :)
