What should I modify nex? Suggestions?
I have a 2000 A6 2.7T. I have put the GIAC "X" chip in the ECU. I have Stratmosphere diverter valves, air intake and just recently added a Miltech Exhaust. In all honesty, car the runs great!
What would be by next in line modification, clutch, anything in the drivetrain. What is my next best step? I appreciate all your expertise! OOOO |
RE: What should I modify nex? Suggestions?
suspension, rims/tires and brakes
I did also put rims and tires on the car!
I am hoping that someone can point me in the direction of performance! I do appreciate the input! [IMG]local://upfiles/13659/063652C786244C6C819899A7552D5C52.jpg[/IMG] |
Depends on how you define performance...
If you want more power & speed off the line, your next step is new turbos, bigger intercoolers, etc. If you've done a chip and a freer-flowing exhaust, you've definitely cranked things up. If you want balanced performance, the suggestion to turn your attention to wheels, brakes, & suspension is a good one. You've got the car moving pretty fast, now make sure it will perform well if you turn the wheel and/or hit the brakes. Have you done the H-sport anti-sway bars yet? That's a MUST from a suspension perspective. Do you have the OEM sport suspension? If not, you should probably look at coilovers/new springs/shocks. The stock brakes are pretty good, but if you want to throw around money, this is not a bad place to do it. You may want to check out Stoney's Links (see my signature for the URL). Lots of ideas in there to tickle your wallet. |
