What sparkies?
Old May 29, 2007 | 10:21 PM
alias747's Avatar
Default What sparkies?
I want to do my spark plugs. What kind should I get and what should they be gapped at?
Old May 30, 2007 | 09:23 AM
alias747's Avatar
Default RE: What sparkies?
no one knows?
Old May 30, 2007 | 09:42 AM
techbod's Avatar
you have a wide choice 3 to be exact
NGK PFRO6Q original equipment
BOSCH 4FR78
CHAMPION RC8PYP
all gaped at 0.8mm
Old May 30, 2007 | 06:31 PM
alias747's Avatar
Sweet thanks a lot bro! Just curious, what ones would you recomend?
Old Jun 1, 2007 | 12:00 PM
onepoint8tee's Avatar
NGK beofre Bosch, and if your lawnmower needs a new plug get Champion.
Old Jun 1, 2007 | 12:02 PM
techbod's Avatar
NGK without a doubt
Old Jun 3, 2007 | 10:58 PM
alias747's Avatar
I went to Autozone and they didnt have any NGK. So I ended up getting some Denso double platinums. These should be good right? Gapped at the same .8mm right?
Old Jun 4, 2007 | 01:04 PM
alias747's Avatar
bump
Old Jun 4, 2007 | 01:10 PM
techbod's Avatar
sounds ok to me check this link out
http://images.google.co.uk/imgres?im...%3Den%26sa%3DG
Old Jun 4, 2007 | 02:09 PM
alias747's Avatar
Thanks for the link!
Look at what it says at one part:
Some of you may or may not know this. But you are not supposed to check the gap on a platinum or iridium plug. Honda reccomends that you dont do this. My theory is that you will embed metal onto the plug which will effect its properties and performance. Just pull out of the box and install.
Is this true? Or should I gap them to .8 mm like you said?
