where can i purchase suction pump for 01 2.7t?
and i am about to do cam tensioner seal replacement and i read somewhere that before i start to loosen cam adjuster with 3366, i need to make sure that i am at TDC. how do i go about doing that? the TDC that is.
RE: where can i purchase suction pump for 01 2.7t?
Are you looking for a different answer than you got 5 days ago? If there was a specific part of my answer that was confusing, let me know and I'll try to clarify.
what i mean is , do i have to remove front bumper and all to get to crankshaft?
If you are doing your valve cover gaskets and camchain tensioner gaskets, you don't need to remove your front bumper.
You just need to remove the belly pan. After that, you can get a wrench on the crank pulley bolt.
Scroll through this link - there's a good picture - http://forums.audiworld.com/a6/msgs/616641.phtml |
thanks mpw2.7t. good info.
