will 02 A4 wheels fit on our car?
I own a 2000 A6 2.7t quattro... i found a guy who has 02' A4 wheels and tires for sale, for cheap i might add, and i was curious to know if anyone knew if they would fit my car.. thanks in advance
RE: will 02 A4 wheels fit on our car?
I just bolted late-model 17' 5 spoke A4 wheels onto my 01 A6 avant (2.8Q). with a 45mm offset, they fit my car with only a few mm to spare on the inside suspension control arm. But they work fine, with no rubbing.
So offsets are key. The 35mm offset on the knock-off aftermarket five spoke A4 wheels (tons on ebay) would give a little more breathing room, but as long as you run with 225/40 R17 tires you'll be okay with stock. The only difference with your car might be brake clearance, but an Audi dealer will be able to tell you if that's a problem.
The best part is they'll transform the look and feel of your car.
AKAUDI
01-29-2015 07:56 AM
eddieau12di
01-11-2013 05:05 PM
OG_35
05-25-2010 12:11 AM
irwins41
08-17-2009 10:41 PM
PlatinumAuto
03-06-2009 12:36 PM
