would any of these pumps work
http://www.autopartswarehouse.com/se...7&Ntt=air+pump
here is a link to some pumps. i have a code that keeps popping up....i was checking online and these seem the be the cheapest.
do you guys think these would work?
i dont have the paper in front of me right now but it was like 17038....or something like that....i had my mechanic look it up and they gave me a quote to fix it and thtas basically what they would be replacing....he said it would only take a hour so im thinking it should be easy to take care of myself
TTT
Has anyone had experience with pumps that aren't spec'd for their car. There seeems to be a large disparity in price for the SAPs on autopartswarehouse (link above).
Do they have different flow rates that will throw codes or is it just the mounting points? The pictures look the same but that might be stock photos.
I have not SAP on my car right now and need to put a new one on before i can sell it or inspect it. Mines an 04 A4 (b6)
https://www.audiforums.com/forum/sho...d.php?t=135963
or more specifically, what's the difference between
W0133-1833559 (2004 A4 pump)
W0133-1800569 (TT/ allroad/jetta, etc of 2000-2006 vintage)
Other than $100 obviously. That is a good reason to get the other one.
Looks like the 559 is sealed with glue and not servicable while the 569 has rivets holding it together and the connectors may be different. I can change out the connector from my bad one if needed.
I can make them work if the flow rate is the same or will not trip the code.
