You're a fool if you don't gap your plugs!
I was a fool for the last 7 years! I never gapped the NGK PFR6Q plugs because everyone always said they were pre-gapped and it says so on the box. BUT I decided to finally check the gaps on a new set I ordered, and they ranged from .25-.29 which is WRONG! I set them to .315 and the engine is now completely different. No more hesistation at all, everything is sooooo much smoother, and there is no stumbling at all at any speed.
Another thing I could have done was to look in the Bentley for which plugs I should be using, it says BKR6ES. But then I read that people like copper plugs in turbo engines... How come ngk says that the pfr6q are the correct plugs only? when in the Bentley it says BKR6ES..... Oh well, I just checked the old plugs (installed a year ago, less than 15k miles), they ranged from .26 to .33 unbelievable!!
Also why does it say here that the BKR6E NGK Spark Plugs 6962 - NGK V-Power Spark Plugs - Overview - SummitRacing.com have a nickel alloy electrode tip? Aren't they supposed to be just plain copper?
The correct NGK spark plugs for 2.0 TFSI are
Platinum: PFR7S-8EG equivalent to Bosch FR6KPP33S
Iridium: BKR6EIX - Figured out myself
I've looked at enough plugs over the years to just kinda-sorta "know" when the gap looks wrong. That and with modern high-energy ignition systems, the gap is becoming less and less important (as long as it's within a certain range).
amazing, I cant tell the difference between .25 and .32. And I really felt a big difference when all my spark plugs were finally gapped correctly at .315 (i took it down a little to account for some extra hp my car has)...
