2000 A8, will not engage reverse gear!
Hi Guys,
I've got a 2000 4.2 A8 Quattro with around 140,000 miles on the clock, yesterday I incurred a fairly terminal problem in that, upon trying to park in london, the transmission refused engage reverse gear, the forward speeds are all still in good working order though. just wandering if anyone else has had this happen to them, and if so was it expensive to fix, ie was a complete rebuild needed?
Any advice would be greatly appreciated,
thanks
thanks
RE: 2000 A8, will not engage reverse gear!
Are you getting limp mode? All the gears lit up?
It could be your F125 switch.
Procedure
or it could be a bad valve body, here is Tozo's post on Audiworld forum.
"The tranny needs around 100 psi pressure for forward gears, but it needs 180-190 psi for reverse. So if you don't have problem with your reverse, then your pump is just fine. As I mentioned earlier, that pump is a monster. It should be able to push 1000 psi easy. It has a regulator right by the pump to dump back the extra pressure. After the regulator it goes to the valve body ( still over 200 psi) and the main pressure regulator valve controls the pressure. My pump was cavitating when I bought the car and I drove it for weeks before the first fluid change. It was loud even whet the car was hot. After the fluid change it was quiet again. When my valve body cracked, it went into limp mode right away. Since there is no fluid pressure control in limp mode, the pressure from the pump cracked my clutch A housing like a pretzel."
Procedure
well the car isn't displaying any problems at all, everything is as normal, no warning lights, but the engine just revs when you engage reverse.
It's the auto tiptronic, sorry, fairly vital piece of information to leave out!
thanks for your help
if it reverses and is slow at take up the I would suspect fluid level, if it doesn't reverse at all then it could be a ball bearing under the gearshift which is plastic surrounded and wears "no Cells will come on but a simple fix" tiptronic = automatic
I have a similar proplem with my 2000 A8L with triptronic. I get reverse at idol speed but no powered reverse ie. I can back up on a flat surface but can not back up a hill or accelerate in reverse. Did you have any luck getting your's fixed? If so, how and how much? Any advise would be greatly appreciated.
[align=left] [/align]
Hi, my 1998 A8 4.2 automatic tiptronic transmission today started doing something weird. when the car is in drive and I accelerate it hardly moves, the engine revs more and it stays like this slowly accelerating until around 35-40 mph and then everything is normal. reverse works. no sign of leakage. trans never been serviced. any idea of the problem and repair costs? the car has only 85,000 miles - but the list of repairs on it over the years is about a mile long...
Hi fellas. Just wondering if anyone found the fix on this? Today my 2000 A6 V8 Tiptronic is doing the same thing. Won't engage in Reverse. Forward driving is just fine. Any suggestions?
Thanks in advance!
Thanks in advance!
Wow I guess Im not the only one with this problem, Yea just a few days ago my 00 Audi A6 4.2 started acting up in reverse, almost like its slipping, I took it to an Import automotive shop who said that it might be a broken band in the trans however Im not going to pay for "Guess Work" so I might be looking into getting a second opinion. It still goes in reverse if its on a flat surface but nothingbut free revs if there is any kind of incline, and ideas would be appreciated, thanks
