2004 A8L Parking break malfunction
I have got myself in a mess. I had the rear breaks replaced on my 04 A8L. I had no idea that this needed to be done using the VCDS, which was not used. I now have 2 faults showing with regards to the breaking system. The parking break flashes in the dash along with the loud ring. I am really hoping there is a way to rectify this?
Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000532 Shop #: WSC 08212 444 83316 VCID: 1D3A19A8C4FB76F02AA 2 Faults Found: 02433 - Supply Voltage for Right Parking Brake Motor (V283) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11111100 Fault Priority: 1 Fault Frequency: 49 Reset counter: 60 Mileage: 150560 km Time Indication: 0 Date: 2011.11.21 Time: 20:45:57 Freeze Frame: Voltage: 12.94 V Count: 87 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 67 Mileage: 150688 km Time Indication: 0 Date: 2013.04.13 Time: 10:36:34 Freeze Frame: Voltage: 11.08 V Count: 61 |
