2004 Coolant Pipe Leak (oil cooler/housing removal question)
Ok I think I have the dreaded coolant leak from the oil cooler housing as I can see clean drips of coolant near the oil pan. I want to confirm that it is a DIY on the D3 A8. The articles I've found are for the D2 body.
The other reason I ask is because for the 2004 A8L, Elsawin is calling for ENGINE REMOVAL as the first step OIL FILTER HOUSING REMOVAL.
Oil cooler repair on 40v 2000 +A8 - LONG post..even for me - AudiWorld Forums
audipages A8 Oil Cooler Removal and Reinstall
2000 A8 40V Oil Cooler Plastic Pipe Replacement | AudiAudi
Also applies to changing wiper blades, rotating tires, adding fuel
I'd recommend getting the actual manual from erWin to verify for that year.
