2005 A8L VCDS Scan with Error Codes
I just scanned my a8l with VCDS, trying to work through some bugs and was hoping that someone on here could possible guide me a bit with some of these error codes and get this cleaned up.
below is the VCDS log I just took. THANK YOU IN ADVANCE! ------------------------------------------------- VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64 Data version: 20160216 Ross-Tech: Home Friday,15,July,2016,13:29:57:53355 Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 67 72 77 VIN: WAUML44E55N016790 Mileage: 294210km-182813miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 J HW: 4E0 907 560 Component: 4.2L V8/5V G 0010 Revision: --H01--- Serial number: AUX3Z0E3762803 Coding: 0007773 Shop #: WSC 02313 785 00200 VCID: 285FE79E9B23707E16-807C 1 Fault Found: 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent Readiness: 0000 1100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 S HW: 09E 927 156 A Component: AG6 09E 4,2L5V USA 0020 Revision: --H01--- Serial number: 0054882 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 326B05F6ADFF0AAEB8-8066 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0007597 Shop #: WSC 22164 000 00000 VCID: 224BF5B6FD1F9A2E48-8076 1 Fault Found: 01435 - Brake Pressure Sensor 1 (G201) 000 - - - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 D Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0E3762803 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: 58BF975EEBC300FE66-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3940576 Shop #: WSC 00000 785 00200 VCID: 2345F0B2E205932643-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 732 S HW: 4E0 035 729 Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 346DN057521860 Coding: 0000003 Shop #: WSC 22164 444 58007 VCID: 326B05F6ADFF0AAEB8-8066 Subsystem 1 - Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 Subsystem 2 - Serial number: 391DK057504460 Subsystem 3 - Serial number: 7411.04.0500000000291B0201˙ Subsystem 4 - Serial number: 1B0201˙ 3 Faults Found: 02244 - Button in Control Head is Stuck 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Mileage: 294171 km Time Indication: 0 Date: 2016.07.14 Time: 19:06:52 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 0001000 Bin. Bits: 000 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 14 Reset counter: 40 Time Indication: 15 00658 - Control Head 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 176 Mileage: 294184 km Time Indication: 0 Date: 2016.07.15 Time: 00:25:36 Freeze Frame: Bin. Bits: 001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 E Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000065139 Coding: 1052993 Shop #: WSC 02311 785 00200 VCID: 1C37CB4EDF7BACDE82-8048 Subsystem 1 - Part No: 4E0 910 772 A Component: Sitzluefter FS H02 010 Subsystem 2 - Part No: 4E0 910 772 A Component: Sitzluefter BFS H02 010 Subsystem 3 - Serial number: 898053000 Subsystem 4 - Serial number: HO30032005065A000000000120˙†89 Subsystem 5 - Serial number: 000120˙†898053000 000-SHO Subsystem 6 - Serial number: 000-SHO24032005065A00000000 Subsystem 7 - Serial number: 65A000000000155˙ No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E1 955 113 B Component: ILM Fahrer H12 0210 Coding: 0143123 Shop #: WSC 22164 444 58007 VCID: 31690AFAA8F931B6C1-8064 Subsystem 1 - Part No: 4E1 910 113 B Component: Wischer WWS D3 H50 0400 Coding: 00000035 Shop #: WSC 22164 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 22164 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE7119967 Shop #: WSC 00000 000 00000 VCID: 1C37CB4EDF7BACDE82-8048 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl Part No SW: 4E0 910 593 G HW: 4E0 035 593 C Component: SDAR XM H04 0670 Revision: 00000000 Serial number: AUZ4Z7D3021401 Shop #: WSC 00000 000 00000 VCID: 2B5518928AD55B66FB-807E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 E Component: Airbag 8.4E+ H10 0920 Coding: 0530707 Shop #: WSC 02313 785 00200 VCID: 2447F3AEE70B941E3A-8070 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0012141 Shop #: WSC 00000 000 00000 VCID: 65C1AEAAACB1AD16ED-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 G HW: 4E0 920 950 G Component: KOMBIINSTR. VDO H54 0210 Revision: D06 Serial number: AUDID3E3004943 Coding: 0000203 Shop #: WSC 03855 444 12345 VCID: 285FE79E9B23707E16-807C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4L0 907 468 B Component: J533__Gateway H06 0071 Revision: 00H06000 Serial number: 1200B127098021 Coding: E5D59F7F307A0E00 Shop #: WSC 22155 444 13987 VCID: 2D51168AB4C15556E5-8078 1 Fault Found: 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 10 Reset counter: 176 Mileage: 289024 km Time Indication: 0 Date: 2016.06.04 Time: 10:27:04 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 22164 444 58007 VCID: 285FE79E9B23707E16-807C 2 Faults Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 25 Reset counter: 176 Mileage: 288802 km Time Indication: 0 Date: 2016.06.03 Time: 10:29:53 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 146 Mileage: 291709 km Time Indication: 0 Date: 2016.06.30 Time: 11:46:44 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071658 Shop #: WSC 00000 785 00200 VCID: 2345F0B2E205932643-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 C Component: MNS US H44 1100 Revision: 00000000 Serial number: 378DS057520636 Shop #: WSC 02313 785 00200 VCID: 387F37DE4B83E0FE86-806C 1 Fault Found: 02927 - DVD Read Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 52 Reset counter: 176 Mileage: 279778 km Time Indication: 0 Date: 2016.03.21 Time: 13:50:16 Freeze Frame: Hex Value: 0x5787 Hex Value: 0x722C Hex Value: 0x04FF Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 Component: Dachknoten D3 H02 0090 Serial number: 00000506100058 Coding: 0003477 Shop #: WSC 02313 785 00200 VCID: 1D31C64AC461A5D675-8048 4 Faults Found: 00213 - Control Circuit for Reading Lights Front Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 192 Mileage: 262136 km Time Indication: 0 Date: 2015.10.02 Time: 19:24:00 00212 - Control Circuit for Reading Lights Front Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 232 Mileage: 262136 km Time Indication: 0 Date: 2015.10.15 Time: 18:53:00 00215 - Control Circuit for Reading Lights Rear Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 67 Mileage: 262136 km Time Indication: 0 Date: 2016.02.28 Time: 19:05:00 00214 - Control Circuit for Reading Lights Rear Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 144 Mileage: 262136 km Time Indication: 0 Date: 2016.03.26 Time: 22:35:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 801 B Component: Türsteuer.FS BRM003 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 204FFFBEF313883E5E-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040504090059 Coding: 0065086 Shop #: WSC 02313 785 00200 VCID: 275DE4A2963D7F061F-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 2 Faults Found: 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 20 Reset counter: 137 Mileage: 292109 km Time Indication: 0 Date: 2016.07.04 Time: 05:42:38 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 181 Reset counter: 137 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0460 Revision: PROD_01 Serial number: 00000000013762 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 2A5B1D96852F426E00-807E No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000059767 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 1E33C146C967BECE6C-804A Subsystem 1 - Part No: 4E0 910 511 A Component: UGDO HL US H02 0030 Subsystem 2 - Serial number: VK4978T0N5TE No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 B Component: Türsteuer.BF BRM003 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 204FFFBEF313883E5E-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 C HW: 4E0 907 801 A Component: EPB A32C0220 H02 0220 Revision: A32C0220 Coding: 0000532 Shop #: WSC 03855 444 12345 VCID: 1F4DFC42CE6DB7C667-804A 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 9 Reset counter: 176 Mileage: 290136 km Time Indication: 0 Date: 2016.06.23 Time: 15:38:44 Freeze Frame: Voltage: 13.04 V Count: 236 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: 62CBB5B6BD9FDA2E08-8036 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 E Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396DY057507844 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 31690AFAA8F931B6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0510 Revision: 00000000 Serial number: 00000000005378 Shop #: WSC 22164 444 69314 VCID: 204FFFBEF313883E5E-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2804240736 Coding: 344530393135313035412056413032383034323430373336 Shop #: WSC 22172 444 57478 2 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 4 Reset counter: 255 Mileage: 289514 km Time Indication: 0 Date: 2016.06.09 Time: 17:24:59 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 147 Mileage: 292028 km Time Indication: 0 Date: 2016.07.01 Time: 23:53:45 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM003 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 1E33C146C967BECE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 Revision: 00010028 Serial number: 00000900031333 Coding: 0232125 Shop #: WSC 22164 444 69314 VCID: 5FCDBC428EEDF7C627-800A No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A Component: SDS 3501 US H45 0630 Revision: 00000000 Serial number: 00000503290295 Shop #: WSC 12336 024 394758 VCID: 346703EE57EB049EAA-8060 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM003 0060 Coding: 0028204 Shop #: WSC 02311 785 00200 VCID: 1E33C146C967BECE6C-804A No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H10 1130 Revision: 00000000 Serial number: 00000007520804 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 285FE79E9B23707E16-807C No fault code found. End-------------------------(Elapsed Time: 03:14)-------------------------- |
