2006 A8L Air Suspension-Front Sitting Low-UnDriveable
Ok this is my problem. I drove home and parked in the garage. I got up the next day to go to work and the front of the car was basically sitting on the ground. So I started it up tried to lift and the compressor makes a sound by car does not lift. Rear is normal. I buy scan tool and this is my error listed below...Is this a leak or is it saying I need to replace the air struts? Pardon me if my question is dumb. I've read everything I can on this issue so now I'm figuring next steps. Thanks. :o
Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285FFED89B65635EF37-807D 4 Faults Found: 01583 - Leak in System Detected 000 - - Freeze Frame: Fault Status: 11100000 Fault Priority: 3 Fault Frequency: 117 Reset counter: 149 Mileage: 171849 km Time Indication: 0 Date: 2014.01.11 Time: 12:42:07 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 197 Reset counter: 189 Mileage: 169907 km Time Indication: 0 Date: 2013.12.17 Time: 17:08:16 01400 - Suspension Level Control 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 11100010 Fault Priority: 2 Fault Frequency: 49 Reset counter: 149 Mileage: 172340 km Time Indication: 0 Date: 2014.01.19 Time: 15:26:45 01577 - Turn-Off due to Over-Temp 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 4 Fault Frequency: 13 Reset counter: 181 Mileage: 172715 km Time Indication: 0 Date: 2014.01.27 Time: 00:21:27 |
Definitely a leak somewhere based on the fault frequency and over temp.
Likely the valve block as called out by G291 or the compressor is so shot that it needs to be rebuilt or replaced. There are some proven, and not hugely expensive, rebuild kits and reman air shocks available now. Start with soapy water to check for a leak. More info on G291: Audi Portal: Sensors Diagnostic . Audi A8 4E (2002 -). G291 Also search G291 and/or suspension here: A8 / S8 (D3 Platform) Discussion - AudiWorld Forums Many very recent threads with similar issues. |
Air Suspension
Ok here is my question, how do I test for leaks? I see soapy water referenced but how do I do that?
Get a spray bottle with water and add some soap to it and spray the area where you believe the leak is. If there is a leak then you will see bubbles.
Originally Posted by WillPerdue
(Post 1467042)
| All times are GMT -4. The time now is 02:43 AM. |
