2007 A8 TPMS Control unit problem / replacement
Hi everyone,
I will describe the problem I have: 2007 A8 For the last 3 months I have been getting intermittent TPMS errors on the instrument panel (not low pressure alerts) about a system malfunction. This would come and go occasionally. Last week, I got a low pressure alert that was false, and then the same TPMS fault and now it wont go away, its there the entire time the car is running. I have tried resetting the pressures but it doesnt work. All 5 wheels show up as blank (no reading) now on the MMI screen. I am assuming the control unit is dead\dying since it doesnt seem related to any specific wheel. I am considering replacing it. The part number is 4E0910273A. Questions, then: Is there a way for me to verify 100% the unit needs replacement? Any way I can 'reset' it or try to get it working again without replacement? If I do have to replace it, this unit lives above the left rear wheel bay, correct? Is this something I can replace on my own without much trouble or can this become an electrical nightmare for me? If its a job I can in fact do, can anyone give me some instructions on how I should do this correctly? |
it might not be the TPMS unit but rather the batteries in the sensors in the wheels are dead or dying.
Do you have access to a VCDS? Run an auto-scan and post the results... I just turned mine off when the batteries died. |
Originally Posted by Gigitty
(Post 1351873)
Do you have access to a VCDS? Run an auto-scan and post the results... I just turned mine off when the batteries died. What is VCDS? Also, the system started to work again, but I continue to get malfunctions. As of now, its an intermittent problem. If its a battery, wouldnt 1 wheel not report? I am getting blanks on all 5. |
Ross-Tech VCDS aka VAG-COM Ross-Tech: VCDS Tour
Originally Posted by idfnl
(Post 1351876)
What is VCDS?
Reinstall TPMS Controller in 2006 Audi A8
(Post 1352058)
You'll need a VCDS to diagnose...most members are willing to lend you a hand in using theirs. Just have to find someone local and willing.
Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 Revision: 00010028 Serial number: 00000900036711 Coding: 0232125 Shop #: WSC 00000 785 00200 VCID: 5FCDFD8B8E621DB282-800A 1 Fault Found: 00003 - Control Module 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 225681 km Time Indication: 0 Date: 2019.01.06 Time: 16:07:12 Freeze Frame: Speed: 121.0 km/h Voltage: 25.50 V (no units): 0.0 Temperature: 0.0°C Temperature: 40.0°C Temperature: 0.0°C Temperature: 0.0°C The coding appears to be correct. Do I need an access code to reset it? |
Let me know how it goes! I am in a similar situation
Recode Tire Pressure Monitoring Control Module (J502). If Tire Pressure Monitoring Control Module (J502 ) is replaced, new control module must be coded. To do this, proceed as follows.
