A8 2004 bolt pattern
Does anybody know if the 19 inch OEM wheels with the bolt pattern 5x112 would fit Audi A8 2004? Currently I have 18 inch standard wheels on them and am looking for OEM 19 inch ones.
Thank you, A. |
5X112 is the stock bolt pattern, same with the A4 and A6.
Might wanna have a looky at this site.http://hartmannwheels.com/audi-wheels |
Gotta be aware of the offset, as well... I don't remember, off the top of my head, but that Hartmann site should have the proper specs for Audis.
offset?!
May I ask, what is off set?
http://og-made.com/archives/2174
Its easier to show you than explain it. |
^^^Yeah, whet HE said!
You HAVE to make sure the offset is (O)riginal (M)anufacture (E)quipment (OEM), or pretty dam close, or you run the risk of having your tires rub when you turn teh wheel; can also affect wheel-bearing life, in extreme cases. Reputable wheel/tire vendors already know what yours is based on Make/Model. Still, it's GOOD INFO to know, when you're shopping for wheels. Can I get an *Amen*?!?! |
