A8 transmission interchange
Has anyone changed a8 transmissions from FUN,FBF,or GQF. I wonder if different transmissions can be interchanged as long as tcm is also changed?
Originally Posted by fast69
(Post 1505482)
Is the A8 even physically set up to accept a clutch system?
Originally Posted by dave944
(Post 1505764)
The rear diff is also coded to the transmission.... A mismatch will cause vibrations. Which usually means the driveshaft and axles need to be swapped as well
