Advice needed on NAV problem, strange headlight issue
My '07 A8 is acting up.
On a business trip yesterday my sat radio started acting up, it would turn off for a second and then come right back on. I thought it was interference but it kept going. Then I noticed a ticking sound. I turned the radio off and heard a tick..tick....tick..tick sound which was coming from right behind the rear seat, under the rear speaker area. The navigation also wouldnt work, I would try and set it, and then it would reset back to where I started every time the ticking started. I checked my navigation dvd, and it wouldnt eject the disk either. It seems stuck. And it seems to be resetting. Can I try and reset it, or remove the disk and try and re-engage the system? Or am I done and need a new nav unit? I tried removing fuses from next to the rear panel where this stuff is but it didnt work. Is there a way to force the disk from the unit? Is the unit easy to remove? ... Second issue: A few days ago, I started having a problem with my headlights. When the car starts, everything is fine, the 'day' lights work just fine. But when I turn the headlights on, the front right 'day' lamp (the normal looking bulb) turns off and the car gives me a headlight warning. Any thoughts? Thanks! |
I believe if you hold down the eject button for 10+ seconds it will spit out the nav disc. However if its the satelite radio thats acting up and the navigation problem occured at the same time i would say there is a glitch with the MMI that needs to be reflashed. It could be as simple as a software update, take it to the dealer, its hard to diagnose without a factory scan tool.
Originally Posted by auditech79
(Post 1177975)
Its the system thats in a restart loop, from what I can tell. Holding down the eject button doesn't release the cd, it seems stuck. Is there a "paper clip" option similar to the one used to force a cd tray on a car open? |
Look in your owners manual and find how to do the MMI re-set. You have to push down three buttons on the MMI panel and it shuts down and reboots itself. See what that does before trying to force something into a $1,000 module.
(Post 1178114)
Thats possible, however if you unplug the power from the back of the unit then plug it back in it should jar it loose. If that doesn't work you will need a new unit.
