Aftermarket Sub
Anyone fitted one?
At the moment i have removed the bose sub and used a line level converter to plug into my amp. works ok. however i would like to get a pre amp signal before the bose amp. where is the bose amp on a d3 2004 A8? left side in trunk? yes but which unit is it? is the unit receiving an optical signal from the MMI unit? or can i tap into the sub signal pre amplifier? ie is it a normal copper cable. If it is optical is there any unit i can use pre amp to let me adjust/tap into the optical feed. the reason i am asking is taht i dont think i am getting a clean signal and the low bass frequencies are really being cut off and very noticable with 2600rms here is the box and yes my camera skills suck https://img72.imageshack.us/img72/813/image012iu.jpg https://img202.imageshack.us/img202/3046/image010ia.jpg https://img231.imageshack.us/img231/1970/image008qh.jpg https://img263.imageshack.us/img263/7176/image007uc.jpg https://img52.imageshack.us/img52/1682/image005td.jpg https://img519.imageshack.us/img519/4677/image004dv.jpg https://img443.imageshack.us/img443/4011/image002lw.jpg |
