Go Back  AudiForums.com > Audi Models > Audi A8
Blauparts Ravenol Audi Automatic Transmission Fluid (ATF) Change Kits * ON SALE * >
Old 10-18-2012, 04:56 PM
Blauparts
Default Blauparts Ravenol Audi Automatic Transmission Fluid (ATF) Change Kits * ON SALE *
Improved German Ravenol ATF Now Used in Our Blau® ATF Change Kits
NOW ON SALE
Blauparts is pleased to announce that our all-inclusive ATF transmission filter change kits now include advanced Ravenol of Germany automatic transmission fluid (ATF).
Ravenol's ATF fluid isn't engineered like other generic brands on the market that cover a broad range of applications. They've based their ATF production upon the German engineering philosophy, which demands that specific transmission designs require specific transmission fluids. Ravenol has been awarded formal approvals from leading transmission manufacturers including ZF, a major supplier of transmissions for Audi and VW. Their formulations consist of the highest quality synthetic Poly-alpha-Olefin base oils (PAO). They uses advanced hydro cracking techniques, and is complemented with unique additive packages that meet the specification for your transmission.
BLAU® Automatic Transmission Fluid (ATF) Filter Change Kits containing Ravenol transmission fluid offer the following benefits:
• Kits include the highest quality base stock synthetic Poly-alpha-Olefin (PAO) (specifications differ per kit depending on application).
• Unique additive packages specifically engineered for the requirements of your specific Audi Vw transmission.
• Optimal lubricating ability and transmission function even at low temperature winter climates.
• Very low pour point, crucial for the properer operation of Audi Vw transmissions in low temperatures winter climates.
• High stability viscosity index for excellent transmission performance in all conditions.
• High thermal stability even when transmissions are subjected to extreme conditions.
• Anti-friction characteristics lowering transmission operating temperatures and extending transmission life.
• Excellent oxidation stability, anti-corrosion ability, keeping the transmission internally clean for extended change intervals.
• Excellent anti-foaming characteristics prevents slippage and provides efficient power transfer.
• Corrosion inhibitors allow for the fluids excellent compatibility with non-ferrous metal alloys found specifically in ZF, Aisin, and Jatco transmissions found in Audi and Vw models.
NOTE: All of the Ravenol transmission fluid bottles work with Blauparts' ATF change pump, which is included free in nearly all transmission kits. The fluid we used previously had an issue with the bottle not working quite right with Our FREE pump. That problem has now been solved with Ravenol! More on Ravenol oils and fluids for Audi models.
Pre-Winter Tip: Winter can add additional stress to transmissions. It's advantageous to change your fluid before winter sets in to improve transmission performance.
Technical DIY Overview on How and Why you should change your transmission fluid.
The Latest Lineup of Audi ATF Specs:
NOW ON SALE
• G 052 162 A2
• G 052 180 A2 CVT
• G 055 025 A2
• G 055 005 A2
• G 052 182 A2 DSG
Check Out Our ATF CLOSEOUTS - Limited to stock on hand.
About Blauparts®
Our vision and success is driven by a passionate commitment to providing the highest OEM quality parts, creating the best customer service experience possible, and helping owners to keep these awesome German cars on the road for years to come! We are confident our customers will be pleased with the high quality of Ravenol ATF. We wish to thank all our loyal customers for their continued support.
Website: www.blauparts.com
Quick Reply: Blauparts Ravenol Audi Automatic Transmission Fluid (ATF) Change Kits * ON SALE *
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
