A/C Cabin filter
Hi folks,
I have 2 questions; 1- How often should the A/C Cabin filter replaced? 2- Where is the filter located and how Do I repalce it? Thanks a lot, A. |
It is located at the very top of the engine. While looking at the engine with the hood up it is closest to the windshield in the direct middle. It is an a oval-esque looking rectangle, Not sure how often but I check mine every so often and if I can just clean it. I'd just replace it when its dirty enough, depends on the conditions you are in.
Thank you for the reply,
Is that easy accessable?
Originally Posted by Brozee
(Post 1200548)
Easilly accessible yes, just remove the hold down screws and it pops right up. You should change it every 20k or so, if you don't you can get an old man musty smell which is very nasty.
Originally Posted by auditech79
(Post 1200898)
Jazz, you're not THAT old are ya!? You haven't even hit 50 yet right!? However i can't tell ya how many D3 A8's i've been in that smell like bengay......:(:(:(
