component locations engine bay data
Old Nov 21, 2007 | 01:26 PM
techbod's Avatar
Default component locations engine bay data
Servicing Motronic fuel injection system[/align]Overview of fitting locations[/align]
Power output stages for ignition coils -N122 and -N192
Engine control unit -J220
Relay and fuse carrier:
â—†Motronic fuses
â—†Motronic current supply relay -J271
â—†Immobiliser relay -J341 [/ul]
Connector for Lambda probe -G39 and Lambda probe heating -Z19
Lambda probe -G39 with Lambda probe heating -Z19
Coolant temperature sender -G62
Intake air temperature sender -G42 [/ul]
Throttle valve potentiometer -G69 with integrated idling switch -F60
Idling speed stabilisation valve -N71
Engine speed sender -G28
Connector of Lambda probe -G108 and Lambda probe heating 2 -Z28
Connector of engine speed sender -G28
Lambda probe -G108 with Lambda probe heating -Z28
Hall sender -G40
Knock sensor II -G66 [/ul]
Ignition coils for cylinders, bank 2
â—†Cylinder 5 -N164
â—†Cylinder 6 -N189
â—†Cylinder 7 -N190
â—†Cylinder 8 -N191 [/ul]
Injectors 5 to 8
â—†Cylinder 5 -N83
â—†Cylinder 6 -N84
â—†Cylinder 7 -N85
â—†Cylinder 8 -N86 [/ul]
Air control valve for injectors -N212
â—†Only vehicles with engine code AKG / AKJ / AKH (MVEG III) and OBDII [/ul]
Variable intake manifold change-over valve -N156 [/ul]
Knock sensor I -G61
Injectors 1 to 4
â—†Cylinder 1 -N30
â—†Cylinder 2 -N31
â—†Cylinder 3 -N32
â—†Cylinder 4 -N33 [/ul]
Ignition coils for cylinders, bank 1
â—†Cylinder 1 -N
â—†Cylinder 2 -N128
â—†Cylinder 3 -N158
â—†Cylinder 4 -N163 [/ul]
Activated charcoal filter system solenoid valve 1 -N80
Air mass meter -G70 in upper section of air cleaner housing [/ul]
[IMG]local://upfiles/12092/D3B59B6BD09045899DBFD61D6DC894F7.jpg[/IMG]
Old Nov 21, 2007 | 06:26 PM
auditech79's Avatar
Default RE: component locations engine bay data
Are you gonna do one for the newer model A8's too?
tallon
Jun 24, 2014 03:11 PM
duffman
Aug 4, 2007 10:41 PM
GA foo 88
May 22, 2006 08:17 PM
Jestnomen
Oct 17, 2005 04:25 PM
Evil Vin
Mar 11, 2005 12:31 PM
