component locations engine bay data
Servicing Motronic fuel injection system[/align]Overview of fitting locations[/align] Power output stages for ignition coils -N122 and -N192 Engine control unit -J220 Relay and fuse carrier: ◆Motronic fuses ◆Motronic current supply relay -J271 ◆Immobiliser relay -J341 [/ul] Connector for Lambda probe -G39 and Lambda probe heating -Z19 Lambda probe -G39 with Lambda probe heating -Z19 Coolant temperature sender -G62 Intake air temperature sender -G42 [/ul] Throttle valve potentiometer -G69 with integrated idling switch -F60 Idling speed stabilisation valve -N71 Engine speed sender -G28 Connector of Lambda probe -G108 and Lambda probe heating 2 -Z28 Connector of engine speed sender -G28 Lambda probe -G108 with Lambda probe heating -Z28 Hall sender -G40 Knock sensor II -G66 [/ul] Ignition coils for cylinders, bank 2 ◆Cylinder 5 -N164 ◆Cylinder 6 -N189 ◆Cylinder 7 -N190 ◆Cylinder 8 -N191 [/ul] Injectors 5 to 8 ◆Cylinder 5 -N83 ◆Cylinder 6 -N84 ◆Cylinder 7 -N85 ◆Cylinder 8 -N86 [/ul] Air control valve for injectors -N212 ◆Only vehicles with engine code AKG / AKJ / AKH (MVEG III) and OBDII [/ul] Variable intake manifold change-over valve -N156 [/ul] Knock sensor I -G61 Injectors 1 to 4 ◆Cylinder 1 -N30 ◆Cylinder 2 -N31 ◆Cylinder 3 -N32 ◆Cylinder 4 -N33 [/ul] Ignition coils for cylinders, bank 1 ◆Cylinder 1 -N ◆Cylinder 2 -N128 ◆Cylinder 3 -N158 ◆Cylinder 4 -N163 [/ul] Activated charcoal filter system solenoid valve 1 -N80 Air mass meter -G70 in upper section of air cleaner housing [/ul] [IMG]local://upfiles/12092/D3B59B6BD09045899DBFD61D6DC894F7.jpg[/IMG] |
RE: component locations engine bay data
Are you gonna do one for the newer model A8's too?
| All times are GMT -4. The time now is 02:59 AM. |
