coolant temperature sensors location?
Old 10-10-2017, 01:52 PM
1999jayman's Avatar
Default coolant temperature sensors location?
Following a t-belt job the low speed fans do not work. I've had the AC turned on regularly since belt was replaced and never noticed the low speed wasn't on. It definitely worked before as i was diagnosing an overheat problem (which led to the thermostat and t-belt job.
Is there a separate fuse for low speed fans or is it only the big 60 amp one?
I'm wondering if one of the temp sensors was left unplugged. There's one behind the engine but are here others that determine when the low speed fans come on? There is a connector on the upper, driver side of the fan unit which seems OK. Are there any other connectors?
fordy86
B7 Models
08-08-2021 08:54 PM
cabrioman1995
10-14-2013 12:50 PM
Stidham
09-14-2010 08:16 PM
zulu411
04-27-2008 10:41 AM
A4NightRider
05-19-2005 12:25 AM
Quick Reply: coolant temperature sensors location?
