A couple of issues with my 2007 Audi A8L
I recently bought the Vag-Com interface from Ross-Tech to try and save money for diagnostics and repairs. I'm not sure that I'm using it correctly but I'd like to explain my problems and see if I can get some help from you guys.
Problem #1.
Some of my dash lights are no longer illuminating...specifically, the lights on the esp button, rear shade, button, park assist button, and all vent ***** on the dash. Additionally, the cigarette lighter light and heated seat illumination in the back aren't lighting anymore. I took my car to Newton Audi in NJ to diagnose, they had my car for 11 DAYS....ELEVEN....and said that they still weren't able to diagnose the problem. Needless to say I'll never go there again. The Service Advisor said the tech 'thinks' it might be the instrument cluster. I bought 2 used ones....$450.00 each to find that the problem still exists! I need help with this one. Not sure how to use the VAG-COM to help diagnose this problem.
Problem #2.
My Bluetooth stopped working. Won't see my phone anymore. Again, I'm not sure how to use VAG-COM to diagnose this problem.
Problem #3.
My TPMS controller doesn't seem to be functioning. When I hooked up my VAG-COM, it doesn't even see the controller. The TPMS and flat tire icon stays illuminated on the instrument panel. When I go to the TPMS functions on the MMI, it says that Tire Pressure Monitoring is OFF. When I turn it on, it initially accepts the command and immediately turns itself OFF. Is the controller defective? ***This issue appeared around the same time as the Bluetooth problem.
Problem #1.
Problem #2.
Problem #3.
#1 - take a look at this thread: Shorted Switch Lights - Page 2 - AudiWorld Forums
It's definitely not the instrument cluster, and unfortunately many techs will replace parts until the problem goes away and/or your wallet is drained.
#2 - please post a complet AutoScan
My guess is it will say 77 can't be reached. They seem to be increasingly dying with age these days.
It could also be a break in the MOST loop, see my answer to #3
#3 - Please post the output of an Optical Bus Diagnostic
VAG-COM Autoscan Results
VCDS
Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.2(x64) Data version: 20140212
Ross-Tech: Home
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,17,August,2014,11:18:05:26300
VIN: WAUMV44E67N001700 License Plate:
Mileage: 138910km-86314mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 34 36 37 38 42 46 47
4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44E67N001700 Mileage: 138910km/86314miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: --H16--- Serial number: AUX3Z0F5795821
Coding: 01060009190F0120
Shop #: WSC 06108 444 59062
VCID: 204FFC0DF3A55F1EBB7-8075
1 Fault Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 137480 km
Time Indication: 0
Date: 2014.07.15
Time: 00:01:02
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0°C
Temperature: 39.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.684 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0010
Revision: --H01--- Serial number: 4192169
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2345F301E2B34406A65-8076
No fault code found.
VCDS
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224BF605FDA94D0EAD3-8077
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F5795821
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BF14ED6B7557DE037-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 2447F01DE7BD433EDFF-8071
VCDS
Self-Diagnosis Log
Page 4
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348EN067503802
Coding: 0000003
VCID: 336503415253D486565-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000010958
Subsystem 3 - Serial number: 0107.06.060000000100010021ÿ
Subsystem 4 - Serial number: 010021ÿ
4 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 138365 km
Time Indication: 0
Date: 2014.08.10
Time: 16:02:20
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Mileage: 138645 km
Time Indication: 0
Date: 2014.08.14
Time: 22:47:46
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 001
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
VCDS
Self-Diagnosis Log
Page 5
Fault Frequency: 1
Reset counter: 46
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:14:02
Freeze Frame:
Bin. Bits: 01
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:11:32
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000098195
Coding: 0037185
VCID: 1C37C8FDDFCD7BFE67F-8049
VCDS
Self-Diagnosis Log
Page 6
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 36633A554121C1AE71B-8063
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8125852
Shop #: WSC 00000 000 00000
VCDS
Self-Diagnosis Log
Page 7
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q00067DJ
Coding: 0532707
VCID: 2643EA159181B12EC1B-8073
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36M0C
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 63328RB4013398CESÿ† 63
Subsystem 5 - Serial number: 398CESÿ† 63428RB40133A2B5Eÿ† 63
Subsystem 6 - Serial number: 3A2B5Eÿ† 63528RB401339969Kÿ† 63
Subsystem 7 - Serial number: 39969Kÿ† 63628RB40133A2AFPÿ† 63
Subsystem 8 - Serial number: 3A2AFPÿ† 63729RB4013851629ÿ† 63
Subsystem 9 - Serial number: 851629ÿ† 63829RB401385194Fÿ
Subsystem 10 - Serial number: 85194Fÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H03000 Serial number: 90025061320148
Coding: 0012241
Component: E0221 H07 0090
VCDS
Self-Diagnosis Log
Page 8
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F5000009
Coding: 0048263
Shop #: WSC 44859 000 1048576
VCID: 2541ED19EC87BA36C81-8070
1 Fault Found:
01704 - Terminal 58 (Dimming)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:11:39
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B065208197
Coding: F5D5DF7F30720E
VCID: ECD7583DCFEDCB7ED7F-80B9
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:07:13
VCDS
Self-Diagnosis Log
Page 9
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FE42D9B95A75EF37-807D
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381ER067500587
Shop #: WSC 06108 444 53704
VCID: 2E531235B971F96E39B-807B
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H04 0090
Serial number: 00000614000035
Coding: 0003477
VCID: 1D31C5F9C4D772F6901-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCDS
Self-Diagnosis Log
Page 10
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040606010053
Coding: 0048702
VCID: 2A5B1E258599954EE53-807F
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 47
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 11:40:50
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H02 0120
Revision: PROD_01 Serial number: 00000000000669
Coding: 0000026
VCID: 2C57183D8F6D8B7E17F-8079
VCDS
Self-Diagnosis Log
Page 11
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000086696
Coding: 0010111
VCID: 1E33C2F5C9D169EE89B-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T15F005
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 43
Mileage: 138288 km
Time Indication: 0
Date: 2014.07.27
Time: 12:59:62
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000922
Shop #: WSC 06108 444 59142
VCID: 1F4DFFF1CEDB60E682D-804A
VCDS
Self-Diagnosis Log
Page 12
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2959E129809F9E56EC9-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396EU067538402
Coding: 0000002
VCID: 31690949A84FE696249-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009968
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2606020892
Coding: 344530393135313035412056413032363036303230383932
Shop #: WSC 00000 128 00289
VCDS
Self-Diagnosis Log
Page 13
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606010241
Shop #: WSC 12336 024 394758
VCID: 3467005D575DD3BE4FF-8061
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6510F1
Coding: 1120403
VCID: DCB708FD1F4DBBFE27F-8089
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720614307110
Coding: 0221208
VCDS
Self-Diagnosis Log
Page 14
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005081707
Coding: 0010900
Shop #: WSC 08219 444 85665
End ---------------------------------------------------------------------
Ross-Tech: Home
Dealer/Shop Name:
Self-Diagnosis Log
VCDS
Self-Diagnosis Log
Page 2
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 137480 km
Time Indication: 0
Date: 2014.07.15
Time: 00:01:02
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0°C
Temperature: 39.0°C
Voltage: 11.684 V
Coding: 0000002
VCDS
Self-Diagnosis Log
Page 3
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
Coding: 4071520
VCDS
Self-Diagnosis Log
Page 4
Coding: 0000003
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 138365 km
Time Indication: 0
Date: 2014.08.10
Time: 16:02:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Mileage: 138645 km
Time Indication: 0
Date: 2014.08.14
Time: 22:47:46
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 001
Freeze Frame:
Fault Priority: 5
VCDS
Self-Diagnosis Log
Page 5
Fault Frequency: 1
Reset counter: 46
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:14:02
Freeze Frame:
Bin. Bits: 01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:11:32
Coding: 0037185
VCDS
Self-Diagnosis Log
Page 6
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
VCDS
Self-Diagnosis Log
Page 7
Coding: 0532707
Coding: 0012241
VCDS
Self-Diagnosis Log
Page 8
Coding: 0048263
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:11:39
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 12:07:13
VCDS
Self-Diagnosis Log
Page 9
Coding: 0015510
Coding: 4071530
Coding: 0003477
Coding: 0032364
VCDS
Self-Diagnosis Log
Page 10
Coding: 0048702
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 47
Mileage: 138361 km
Time Indication: 0
Date: 2014.08.10
Time: 11:40:50
Coding: 0000026
VCDS
Self-Diagnosis Log
Page 11
Coding: 0010111
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 43
Mileage: 138288 km
Time Indication: 0
Date: 2014.07.27
Time: 12:59:62
Revision: A32C0220
Coding: 0000922
VCDS
Self-Diagnosis Log
Page 12
Coding: 0000018
Coding: 0000002
VCDS
Self-Diagnosis Log
Page 13
Coding: 0032364
Coding: 1120403
Coding: 0032364
Coding: 0221208
VCDS
Self-Diagnosis Log
Page 14
Coding: 0010900
Sunday,17,August,2014,11:32:55:26300
VCDS Version: Release 12.12.2 (x64)
Control Module Part Number: 4L0 910 468
Component and/or Version: J533__Gateway H06 0040
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
77-Telephone OK OK
47-Sound System OK OK
67-Voice Control OK OK
56-Radio OK OK
37-Navigation OK OK
77-Telephone OK OK
56-Radio OK OK
37-Navigation OK OK
It's good to see the Optical diagnostic passed.
There's definitely something electrical going on here.
That dimming short to ground makes me wonder if it isn't the scenario of that other link I posted.
Check all your CAN bus connections too.
See the wiki entry for 01317.
Only one of the DTCs is older than a week.
First thing to do is clear them, and see what shows up in a scan after a couple of drive cycles.
