D2 2000 Tranny Problems...
Ok so heres what happened, I have an 4.2L A8 Q. The Tranny feels fine and drove great until I was driving home one night and at a stop light I hit the gas and I went no-where. It then made a clunk and went into limp mode. I continued driving and at about 40 mph I put the car into (N) and turned the car off and back on put it into triptronic and I shifted all the way down to 2 and then hit the gas and the car shifted itself all the way into 5th gear and went into limp mode again. Reverse works fine for the record.
I plugged into the car and got a P0730 code and a friend told me to put some ATF fluid in it because sometimes low levels cause this. So I crawled down under the car and I am pretty sure I heard what I think was the tranny pump cavitating, so I added about 2.5 quarts before it started pouring over the fill area, this was done while the car was running in (P); I tested it again and now I get 3 codes the same P0730 and these 2 P0751, P0753.
P0730: Incorrect Gear Ratio
P0753: Shift Solenoid "A" Electrical
P0751: Shift Solenoid "A" Performance or Stuck Off
I was reading about the shift solenoid and that it may need to be replaced, I have also heard of flushing the fluids and putting in a new filter and new fluid, but I am not sure what to do, Anyone who has had similar or the same problems please help?
... I will look for this todo character... thanks!!!
