D3 instrument cluster faulty -repairable?
I bought the instrument cluster from a junk yard which had an Audi that has been in an accident. I bought the instrument cluster and the other components needed because I want to have the adaptive cruise control. Everything is installed and the distance Control Module gives me one fault. To check the instrument cluster for DTC.
After I installed the cluster I took it to the dealer to remove the Component Protection. That worked well. The cluster works as in it displays the speed, the lightning works. If I do the output test on the cluster sometimes the last test shows the red arrows that would show at what speed the cruise is set to around the speedo and sometimes it does not. Also, it doesn't display in how many miles the next service is due. I know the other cluster did display that.
This is the code I got once and I could not get into the cluster at all till I removed the positive from the battery for a while.
__________________________________________________ ___
Address 17: Instruments Labels: None
VCID: 55AA69C28573
No Faults Found
or DTCs not supported by controller
or a communication error occurred
This is the code I have since the Component Protection was removed with the exception of the one that I mentioned above:
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 930 HW: 4E0 920 980 C
Component: KOMBIINSTR. VDO H51 0080
Revision: D13 Serial number: AUDID3C9000265
Coding: 0016233
Shop #: WSC 03323 444 64434
VCID: DFC6CBEA7755
1 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Mileage: 102566 km
Time Indication: 0
Date: 2008.10.02
Time: 02:34:45
I assume that 2008.10.02 was the date of the accident.
Now, I have the original cluster and I'm wondering if there is such thing as removing the module out of the original one and install it in this one and recode the module for this cluster. Or, is it repairable?
VCID: 55AA69C28573
No Faults Found
Coding: 0016233
VCID: DFC6CBEA7755
1 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 102566 km
Time Indication: 0
Date: 2008.10.02
Time: 02:34:45
00003, a8, audi, cluster, control, controller, d3, dtcs, faults, found, gauge, instrumental, instruments, module, supported
