Dash display ( Radio )
Hello, I have a 2003 s8 thats new to me. I know the radio display should show up on the display on the dash at the top, But all i get up there is a picture of what looks to be a headlight. Is there something not working on the headlights and its letting me know? Thanks for all and any help. Mike
Warning lights take priority over radio display.
If it has a "!" in the headlight graphic, it's a problem with the auto leveling of the HID low beams. |
Thanks, Any way to determine which one? I have had the Lt one apart, also i have some other parts headlights around for that so i am hoping i can figure out which one. I own a body shop so its not a problem for me to repair if i can pin point the problem. Thanks
Ok so i pulled the rear covers off the headlights, Each headlight assembly has a think that looks like a little motor to adjust it but i dont see any wires going to it. Also what tells it it needs to be leveled and what senses its not ? I do see a switch hooked to the LT front lower control arm, is that for the headlights? What parts should i be inspecting to cure my problem.Thanks for any help. mike
