Dealing with DRL's and Xenons...
I installed an HID Xenon kit which works great in the OEM projectors (nice clean cut light beam). Problem is the with the DRL's.. the DRL's are normally the lowbeam headlights with reduced power, but reduced power in the xenons makes them flicker (when lights are ON, with full power everything is fine).
Is it better to completely disable DRL's ? Through vag-com? How? Or install some sort of relay with the lights powered directly to +12v ? |
