G45 / Parking Brake Warning on DashBoard
I have been getting the following the issue,
Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 E Component: ESP 5.7 allrad H29 0420 Coding: 0007597 Shop #: WSC 02313 000 00000 VCID: 2143088DF8371729411-8074 3 Faults Found: 00003 - Control Module 014 - Defective 00285 - ABS Wheel Speed Sensor; Front Right (G45) 012 - Electrical Fault in Circuit 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent I just changed the G45 Wheel Speed Sensor, but am getting the same error, but now I am getting 01314 also know. Most annoying issue is that the car keeps beeping saying that the parking brake has failed. ABS light is on. Any ideas on this issue? |
I would like to add that I have the following error
Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000532 Shop #: WSC 08167 444 53222 VCID: 1D3B347DC44F33C9659-8048 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 254 Reset counter: 209 Mileage: 221280 km Time Indication: 0 Date: 2015.03.30 Time: 20:34:42 Freeze Frame: Voltage: 13.46 V Count: 236 |
