have a check engine light and got codes
Hi
I have 2000 Audi A8, have these codes on the car, when i go to start the car, it will turn but no start i just installed a new radiator, before the install the car started up,had some trouble but did start, what could be the issue??? VAG-COM Version: Release 409.1-US Chassis Type: 4D - Audi A8 D2 Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76 ------------------------------------------------------------------------------- Address 01: Engine Controller: 4D0 907 559 Component: 4.2L V8/5V G 0006 Coding: 06653 Shop #: WSC 06449 WAUFL54D3YN002476 AUZ7Z0X1070202 11 Faults Found: Friday, 13 March 2009, 23:04:26 VAG-COM Version: Release 409.1-US Control Module Part Number: 4D0 907 559 Component and/or Version: 4.2L V8/5V G 0006 Software Coding: 06653 Work Shop Code: WSC 06449 Additional Info: WAUFL54D3YN002476 AUZ7Z0X1070202 11 Faults Found: --------------------------------------------------------------------------------------------- 17833 - EVAP Purge Valve (N80): Short to Ground P1425 - 35-00 - -Tank Vent.Valve Short to Ground / EGI glow plug secondary failure 17984 - Shareware Version. To Decode all DTCs P1576 - 35-00 - - Right Eng. Mount Solenoid Valve Short to ground 17980 - Shareware Version. To Decode all DTCs P1572 - 35-00 - - Left Eng. Mount Solenoid Valve Short to ground 17843 - Secondary Air Pump Relay (J299): Short to Ground P1435 - 35-00 - -Sec.Air Inj.Sys.Pump Relay Circ. Short to ground 17938 - Shareware Version. To Decode all DTCs P1530 - - Camshaft Control Circuit Short to ground 17829 - Shareware Version. To Decode all DTCs P1421 - 35-00 - -Sec.Air Inj.Valve Circ Short to Ground 16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 35-10 - - Mass or Volume Air Flow Circ Low Input 17880 - Shareware Version. To Decode all DTCs P1472 - 35-00 - - EVAP Emission Contr.LDP Circ Short to Ground 17529 - Shareware Version. To Decode all DTCs P1121 - 35-00 - - O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground 17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground P1117 - 35-00 - -O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground 16705 - Shareware Version. To Decode all DTCs P0321 - 35-00 - - Ign./Distributor Eng.Speed Inp.Circ Range/Performance ------------------------------------------------------------------------------- Address 02: Auto Trans Controller: 4D0 927 156 CP Component: AG5 01L 4.2l5V USA 1414 Coding: 00002 Shop #: WSC 02314 1 Fault Found: 18265 - Load Signal: Error Message from ECU P1857 - 35-10 - - Load Signal Error Message from Engine Contr. ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Coding: 0273004284 Shop #: BB 24334 No fault code found. |
Thats too many fault codes not to be related to each other, erase the fault codes and see what comes back.
I moved this thread to the A8 forum, as you can see as you don't have an A4. |
thanks, well the car doesnt start, i think i need to do my crankshaft speed sensor
Did you erase the fault codes first?
yea still come back, but looks i need to get that crankshaft speed sensor replaced
Ok...
the car doesnt start after replacing the engine speed sensor
No shit? I would have never guessed... JK. If you have that many fault codes you need to check all the fuses and relays. More than likely a fuel pump relay or something is out.
worked before radiator / does not work after radiator = you missed something in the install - double and triple check your wiring something major is not connected anymore or you broke a connector somewhere.
k i ll check
