have a check engine light and got codes
Hi
I have 2000 Audi A8, have these codes on the car, when i go to start the car, it will turn but no start i just installed a new radiator, before the install the car started up,had some trouble but did start, what could be the issue???
VAG-COM Version: Release 409.1-US
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Address 01: Engine
Controller: 4D0 907 559
Component: 4.2L V8/5V G 0006
Coding: 06653
Shop #: WSC 06449
WAUFL54D3YN002476 AUZ7Z0X1070202
11 Faults Found:
Friday, 13 March 2009, 23:04:26
Control Module Part Number: 4D0 907 559
Component and/or Version: 4.2L V8/5V G 0006
Software Coding: 06653
Work Shop Code: WSC 06449
Additional Info: WAUFL54D3YN002476 AUZ7Z0X1070202
11 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00
- -Tank Vent.Valve Short to Ground / EGI glow plug secondary failure
17984 - Shareware Version. To Decode all DTCs
P1576 - 35-00
- - Right Eng. Mount Solenoid Valve Short to ground
17980 - Shareware Version. To Decode all DTCs
P1572 - 35-00
- - Left Eng. Mount Solenoid Valve Short to ground
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00
- -Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
17938 - Shareware Version. To Decode all DTCs
P1530
- - Camshaft Control Circuit Short to ground
17829 - Shareware Version. To Decode all DTCs
P1421 - 35-00
- -Sec.Air Inj.Valve Circ Short to Ground
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10
- - Mass or Volume Air Flow Circ Low Input
17880 - Shareware Version. To Decode all DTCs
P1472 - 35-00
- - EVAP Emission Contr.LDP Circ Short to Ground
17529 - Shareware Version. To Decode all DTCs
P1121 - 35-00
- - O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00
- -O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
16705 - Shareware Version. To Decode all DTCs
P0321 - 35-00
- - Ign./Distributor Eng.Speed Inp.Circ Range/Performance
Address 02: Auto Trans
Controller: 4D0 927 156 CP
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 02314
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10
- - Load Signal Error Message from Engine Contr.
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 01: Engine
Coding: 06653
Shop #: WSC 06449
11 Faults Found:
11 Faults Found:
P1425 - 35-00
P1576 - 35-00
P1572 - 35-00
P1435 - 35-00
P1530
P1421 - 35-00
P0102 - 35-10
P1472 - 35-00
P1121 - 35-00
P1117 - 35-00
P0321 - 35-00
Coding: 00002
Shop #: WSC 02314
1 Fault Found:
P1857 - 35-10
Coding: 0273004284
Shop #: BB 24334
