Headlight washers stuck open??
Hi All,
Having sorted the problem with the rear lights, the headlight washers decided to get stuck. They are partially out of the front bumper, and see reluctant to move either way when I manually try and adjust them. Does anyone have any idea what it could be? I should add that the cover was covered in snow this morning, so I am wandering if the cold weather has something to do with it... Thanks in advance |
Do you use antifreeze cleaner? If not, frozen fluid probably pushed them out.
