Help!!!! '99 A8 New Battery, Won't Crank or Start
Hi All, I just installed a new battery on yesterday. The radio and dash lights up. However, when I turn the ignition, I get absolutely nothing. I connected it up to VAG and received no error codes. I'm completely stumped at this point and need your expert help. Yes, I'm a newbie and don't mind wrenching it myself as long as I know where to start (LOL).
Thanks,
Mace
Thanks,
Mace
Does the engine crank when you turn on the ignition? If so, do you hear any clicking from the fuel pump? The most common reason from what you have described could be one these elements. You should check the spark plugs, injectors and filters too, if the engine is cranking properly.
