Help!! its raining in my car!
Hi All, i have a huge problem with a D3 A8. Recently we have been having prolonged spells of rail here in the UK (i know not that unsurprising) but the other day i went to get in my car and there was water all over the center console. I dried it off quickly but when driven you can hear water "sloshing" when you corner and it also came out of the small vents near the sunroof controls.
Well a couple of days or so passed and the sloshing had stopped, but then last night we had heavy rain again, again the center console was wet but this time its taken out all of the controls on that too
How can i clear the drains in this car?? and more importantly how can i fix the MMI/sunroof and anything else its taken out Any guides for removing the center console? i have checked all the fuses for the relevant parts that now arent working and theyre all fine, which is a real s**t.
Has anyone got any diagrams or how to's for the D3? all ive found so far was for D2.
Help!!!
Help!!!
Excellent write up by the famous PaulW here audipages Unclogging the A8 Evaporator Drains on the D3 A8
hey all, an update on this, the problem is arguably getting worse. I checked the evaporator drains, both 100% clear, nothing in them at all yet water is still going everywhere. Not a small amount either.
I started to take a few bits of trim off yesterday to see if i could spot anything at all, and came across this when i removed the sunroof control panel and gave it a prod.
Does anyone have a diagram of where these channels run? as after a shower yesterday i drove the car and when i turned a corner id say around 0.5 litre of water gushed out on to the rear seat this should not be happening on a car like this :/ The sunroof does not appear to be leaking at all, we even poured a few gallons of water over the car quickly the other day with me sat in it to see if it leaked and there was nothing.....its completely perplexing....
Can anyone help???
Can anyone help???
Suspect the sunroof drains are backed up based on the video.
In the front there are two small holes, one on either side.
Use a long flexible plastic stick to push down through them.
They drain through the wheel wells via a tube that runs down through the A and D pillars.
I'm not sure where the rear drains begin in the roof though.
There are some pictures and I think diagrams on the AudiWorld forum.
will it bea easier to just remove the roof lining and get to them all? i dont really want to have to do any of this stuff again. The cars giong in to have all the electrics that this has taken out fixed so i realy dont want it returning...
Have a look here: http://forums.audiworld.com/showthre...=sunroof+drain
and here: http://forums.audiworld.com/showthre...sunroof+drains
