Help - Rear Seat AirBag coding and MIL
Hi Everyone,
I must first thank everyone on this site, people taking time out of their busy schedules to help other owers with answers and DIY's. I have learned a lot from this the threads in just a few days. However I have a problem with my rear seat airbag and not able to find answers anywhere. The rear seat on this car was stolen under the previous ownership and was replaced. The wiring was spliced and not hooked back up. I read the wiring diagrams and hooked up everything. I have read lot of forums and searched google for hours but not found code for Airbag controller. I have read the Ross-Tech wiki page regarding the coding but my VCDS software does not suggest me any coding. Can someone please suggest me what to do here. Before hooking up all the wires under the seat to the red plug and the abs Yellow connector I was getting these errors. Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 E Component: Airbag 8.4E+ H10 0920 Coding: 0530707 Shop #: WSC 93030 999 04879 4 Faults Found: 01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145) 000 - - - MIL ON 01220 - Rear Side Airbag Igniter; Passenger Side (N202) 001 - Upper Limit Exceeded - MIL ON 01219 - Rear Side Airbag Igniter; Driver Side (N201) 001 - Upper Limit Exceeded - MIL ON 01044 - Control Module Incorrectly Coded 000 - - - MIL ON -------------------------------------------------------------- Now after clearing the codes and wiring connected I get this. --------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 E Component: Airbag 8.4E+ H10 0920 Coding: 0530707 Shop #: WSC 93030 999 04879 2 Faults Found: 01044 - Control Module Incorrectly Coded 000 - - - MIL ON 01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145) 000 - - - MIL ON ---------------------------------------------------------------- Here is a full scan of the vehicle. VCDS Version: Release 908.0 Data version: 20090911 Wednesday,29,December,2010,22:06:59:13314 Chassis Type: 4E0 Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 72 75 76 VIN: WAUML44E04N018414 Mileage: 100120km/62211miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 75-Telematics -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4E0 910 560 A HW: 4E0 907 560 Component: 4.2L V8/5V G 0070 Revision: 00000000 Serial number: AUX3Z0D0532610 Coding: 0007773 Shop #: WSC 02313 785 00200 1 Fault Found: 18282 - Valve for Torque Support Mount: Short to Plus P1874 - 001 - Upper Limit Exceeded Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 E HW: 09E 927 156 A Component: AG6 09E 4,2L5V USA 0110 Revision: 00000001 Serial number: 0028742 Coding: 0000002 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 N Component: ESP 5.7 allrad H44 0500 Coding: 0007597 Shop #: WSC 93023 000 00000 1 Fault Found: 00003 - Control Module 014 - Defective ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 A Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D0532610 Coding: 0263168 Shop #: WSC 02311 785 00200 Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3940448 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 729 J HW: 4E0 035 729 Component: Interfacebox H43 0600 Revision: 00000000 Serial number: 343HU047538571 Coding: 0000103 Shop #: WSC 93023 999 53727 Part No: 4E0 910 611 Component: E0380 BedienteilH03 0040 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 A HW: 4E0 820 043 B Component: KLIMAAUTOMAT 016 0260 Revision: 00000021 Serial number: 00000000025553 Coding: 1085761 Shop #: WSC 02311 785 00200 Part No: 4E0 910 772 A Component: Sitzluefter FS H02 010 Part No: 4E0 910 772 A Component: Sitzluefter BFS H02 010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0111104 Shop #: WSC 02313 785 00200 Part No: 4E1 910 113 B Component: Wischer WWS D3 H40 0380 Coding: 00000036 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 C HW: 4E0 035 111 Component: CD-Changer H43 0340 Revision: 00000501 Serial number: AUZ5ZBC1031041 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 A HW: 4E0 959 655 E Component: Airbag 8.4E+ H10 0920 Coding: 0530707 Shop #: WSC 93030 999 04879 2 Faults Found: 01044 - Control Module Incorrectly Coded 000 - - - MIL ON 01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145) 000 - - - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 A Component: Lenksäulenmodul H13 0040 Coding: 0012241 Shop #: WSC 02311 785 00200 Part No: XXXXXXXXXXX Component: Lenkradmodul H04 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-***-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 900 E Component: KOMBIINSTR. VDO H44 0090 Revision: D15 Serial number: AUDID3D0019717 Coding: 0016333 Shop #: WSC 93030 999 179353 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 A HW: 4E0 907 468 C Component: Gateway H07 0030 Revision: 07 Serial number: 0200503C041245 Coding: FCFE7BDD1B2304 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 A Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D0532610 Coding: 0263168 Shop #: WSC 02311 785 00200 Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0015510 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071522 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 C Component: MNS US H43 1100 Revision: 00000000 Serial number: 355AP047515197 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 Component: Dachknoten D3 H01 0090 Serial number: 00000405400153 Coding: 0003477 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: None Part No SW: 4E1 910 802 HW: 4E1 959 801 Component: Türsteuer.FS BRM007 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040401090112 Coding: 0065086 Shop #: WSC 02313 785 00200 Part No: 4E0 910 853 Component: Heckdeckel H06 0050 Part No: 4E0 907 719 Component: Neigungssensor H02 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 H HW: 4E0 035 223 B Component: DSP-High D3/AUX H13 0370 Revision: Dev_D01 Serial number: 00000000674950 Coding: 0000016 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H08 0020 Revision: Serial number: 00000000031184 Coding: 0010111 Shop #: WSC 02313 785 00200 Part No: 4E0 910 511 A Component: UGDO HL US H02 0030 1 Fault Found: 02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 232 Mileage: 100128 km Time Indication: 0 Date: 2003.10.09 Time: 12:31:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: None Part No SW: 4E1 910 802 HW: 4E1 959 802 Component: Türsteuer.BF BRM007 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.lbl Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000532 Shop #: WSC 93030 999 179353 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: None Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 02311 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 C HW: 4E0 035 541 Component: TUNER EU/US/RDW H41 0290 Revision: 00000000 Serial number: 304AS047557569 Coding: 0000002 Shop #: WSC 02313 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 B HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0240 Revision: 00000000 Serial number: 00000006291475 Shop #: WSC 93023 999 00850 Part No: 000 915 105 AK Component: von VA0 1401010429 Coding: 303030393135313035414B56413031343031303130343239 Shop #: WSC 00000 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM007 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 0210 Coding: 0212127 Shop #: WSC 02313 785 00200 2 Faults Found: 01472 - Aerial for Monitoring Front Left Tire Pressure (R59) 004 - No Signal/Communication - Intermittent - MIL ON Freeze Frame: Fault Status: 10100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 232 Mileage: 100128 km Time Indication: 0 Date: 2003.10.09 Time: 12:21:40 Freeze Frame: Speed: 0.0 km/h Voltage: 13.50 V (no units): 130.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. 01477 - System Switched Off 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 2 Reset counter: 192 Mileage: 100128 km Time Indication: 0 Date: 2003.10.09 Time: 12:21:39 Freeze Frame: Speed: 0.0 km/h Temperature: -2.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM007 0110 Coding: 0028196 Shop #: WSC 02311 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 75: Telematics Labels: None Part No SW: 4E0 910 616 HW: 4E0 035 616 A Component: Telematik USA1 0070 Revision: 00000004 Serial number: 0000ATD3007649 Coding: 0000005 Shop #: WSC 93023 999 01426 1 Fault Found: 01531 - Emergency Battery 002 - Lower Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H11 0010 Revision: --.--.-- Serial number: 08730402100414 Coding: 0001208 Shop #: WSC 02313 785 00200 No fault code found. End --------------------------------------------------------------------- |
