help sought - front bulkhead/water
I just ran my A8 through a car wash, only to find that water is not draining through the front bulkhead, and it fills up like a swimming pool! I can't imagine Audi designing it that way - I tried to see what's going on, but can't locate drain holes or anything. Any help with this problem, or tips on dismantling the items located in the bulkhead would be appreciated!
Many thansk Q |
RE: help sought - front bulkhead/water
I did a quick search on the forums, here, for "water" and "drain," and came up with the following:
https://www.audiforums.com/m_23077/m...n/tm.htm#23448 https://www.audiforums.com/m_31621/m...n/tm.htm#31621 https://www.audiforums.com/m_31892/m...n/tm.htm#31892 https://www.audiforums.com/m_38220/m...n/tm.htm#38281 https://www.audiforums.com/m_56636/m...2Cdrain/tm.htm |
Thanks for the info ... it seems like some people had issues with the pollen filters/draining, so I'll try to strip mine out and see if I can see more.
Regards Q |
