How Many Dash Warning Lights Should Come On When Starting The Car?
I have an 02 A8L and I am having a problem with my ABS and ESP not working. I just had a snow storm and I am positive the ABS is not working. The strange thing is neither warning light is on. Also when I start my car only a few of the warning lights come on Generator, EPC, AIR BAG, CHECK ENGINE, AND ELECTRONIC IMMOBILIZER are the only lights that come on. Also when I push the ESP button nothing happens. Where should I begin? The car runs great but I live in Cleveland and need the ABS. It almost seems like something needs to be reset or something is not plugged in.
well,
easiest way is to find a friend or go to shop to connect your Audi to VAGCOM software, then you will se whats bothering your little car. after that post results here, so someone can help you. first diagnostics, then you go share your wealth to local mechanics :D |
well,
Been a little swamped due to the holidays but I will see if I can get that done over the weekend.
Willie |
