iPod & A8
I looked on Audi's web site to see if Audi has a hook-up. I found the following:
"iPod Cable for AMI Item Number: 4F0051510E iPod cable to integrate Audi Music Interface (AMI) with your iPod. The main iPod menu will be displayed in the Multi-Media Interface (MMI) screen. The central control knob on the MMI panel, or the multi-function steering wheel controls, may be used to easily navigate through playlists, albums and artists. Compatible with vehicles 2008 and older with AMI " Does the above cable work with a 2005 A8? If yes...it is easy to install? If no, who makes an aftermarket plug in that works well. I don't want to go the way of the FM transmitter type, as they sound like s*&t Thanks |
Yes it works on an 05, and it works very well. But no, its extremely hard to install without specific technical knowledge of the A8's electrical systems.
I don't know of any other cable that is compatible with the A8 besides the factory one, but i could be wrong. |
GROM audio offers solutions for ipod connectivity. For my 2000 A8, GROM makes a device that transfers to the CD Changer input and allows me to control playlists (up to six) as if they were CD's (I would have to disconnect my trunk-mounted changer for this feature). The 2005 model likely has a solution as well.
Can the dealer do this?
Originally Posted by auditech79
(Post 1034487)
Yes the dealer can do it, probably 2-2.5 hours of labor.
Re: iPod & A8 Reply to Thread
I am new so please bear with me if I unintentionally ask questions that have already been asked or answered. Do you need a new AMI unit or the ipod cable (4F0051510E) is all that is needed to hook up to existing 6-CD changer with Nav/XM sat factory installed radio? Thanks!
I don't recognize that part number, i would check with the dealer because there have been a lot of scams online about modules that you don't need. If someone online tells you that you need a control module and tries to sell it to you DON'T DO IT! Check with the dealer.
Have the same issue. I want to retrofit my 2005 A8L with factory installed NAV/6CD/XM SAT/Bluetooth and MMI with a back-up camera and ipod interface, but having problems finding a kit/parts for intended project. I checked with GROMAUDIO after reading a post on the forum but I was informed by GROMAUDIO their interface wouldm't work with 2005 A8L with MMI - so I am back to square one! Any Ideas?
