My A8L with new 20's
2 Attachment(s)
hey guys just put my new wheels on this weekend.
what do you guys think? Opinion welcome.... Asanti 20in wheels (staggered) Tires: 255 /35 /20 I drive the BMW 745LI Wifey drives the A8L |
Not my flavor, but the right size for the car. How much wider are the rear wheels than the fronts if they're staggered? You can't be running the same tire size with a staggered wheel set up are you?
wheelsssss
aaaaaahhhhhhhhhh!!!!!!!!!!!!!!!!!!!
niceeeeeeeeee |
Originally Posted by auditech79
(Post 1238790)
Yeah, I question that too. The same size tire on a different width rim has different handling characteristics...more side roll on a narrower rim and maybe even a hair different diameter. Plus, in general, unless specifically engineered for it, AWD should have the same size on all 4 corners. Bigger on the rear may look cool, but may actually impede balanced handling....not to mention drive train load distribution, if a different diameter. But, again, even when staggered wheels are called for, the rear tires need to be a different size. Staggering actually serves a real purpose on a lot of high powered RWD cars, like past P-928's I've owned...different tires required on front than rear always, though. |
Did you get TPMS installed with them and if so how much did they cost total for tires rims and TPMS? or did you just disable it via vag-com?
Not my flavor, but the right size for the car. How much wider are the rear wheels than the fronts if they're staggered? You can't be running the same tire size with a staggered wheel set up are you? Did you get TPMS installed with them and if so how much did they cost total for tires rims and TPMS? or did you just disable it via vag-com? Plus, in general, unless specifically engineered for it, AWD should have the same size on all 4 corners. Thanks for the reples guys. keepin comin. By the way this is wifeys car :) |
Truly no offense intended, but just one more question...and it IS rhetorical:
You knowingly bought staggered rims, with the intention of rotating back to front ??!! If you're happy, I'm happy ...it doesn't affect me, except to make me scratch my head and it's already getting a little thin up there :) |
You knowingly bought staggered rims, with the intention of rotating back to front ??!! |
LOL, the point of a staggered wheel set up is so give more traction to the rear wheels (on a RWD car) and they CANNOT be rotated, its a very expensive way to roll around replacing tires every 40k. I would see if you could bolt up the wheels to the BMW, because at least thats RWD and it would like fine on it, hopefully its the same bolt pattern.
Well it sounds as if someone will be putting the square peg in the round hole.
If the diameter is all the same your good to go with your AWD if not well then.... your drive train is going to feel the pain. You should grab a tape measure and wrap the tires. |
