AudiForums.com
-   Audi A8 (https://www.audiforums.com/forum/audi-a8-10/)
-   -   Play video on MMI high 2G (https://www.audiforums.com/forum/audi-a8-10/play-video-mmi-high-2g-214933/)
sherry 03-29-2015 08:55 AM
Hi Guys,
I have just got a 58 plate A8 and it has MMI 2G high. It has factory fitted Freeview TV, Sat Nav, BOSE, DAB radio and AMI.
I have a usb and blue connector ipod cables for the AMI.
Is there any way i can get to watch videos?
I can play the video files through usb and ipod but i am only getting the audio.
Any help would be great
Cheers
snapdragon 04-02-2015 04:28 PM
Buy an MMI 2G TV Aux in cable.
It has 3 phono plugs at one end and pins to insert into the TV tuner multi-pin plug at the other. You may also have to enable AUX1 and or AUX2 with VCDS to make the menu options appear in Source.
sherry 04-03-2015 05:06 AM
Thank you for the info.
Will this alow me to control what i watch from the mmi unit?
snapdragon 04-03-2015 07:35 AM
No, there is no way to watch videos from the AMI.
This cable is Aux-in.
You can watch any video from anything with composite video out such as iPhone with composite out cable, Kivic One, media player etc... but you can't control them.
sherry 04-03-2015 10:59 AM
the kivic one looks promising, cheers
snapdragon 04-04-2015 07:37 AM
I have one and it is rather buggy with iPhone 6 / iOS 8 (it was fine with my 4s and ios 7). If you are getting content off 4G it won't show on the MMI unless you use screen mirroring.
I don't know if it is better with android - or maybe wait for a firmware later than 1.2.2.
sherry 04-04-2015 08:01 AM
I have done a bit of searching online and i have came across Dietz 1549 IMU ® Multimedia Interface AUDI MMI 2G and a Dietz 85700BL Car DVD Player with USB Connection which is controlable through MMI.
I then found a Dietz BOA 85600 Full HD HDD Multimedia Player USB SD disks Car Player HDMI. I have contacted the a website to see if this can be controlled from the MMI too.
Hopefully it is as this is exactly what i am looking for :)
junkangh 07-17-2023 07:03 PM
Fantastic information, I'm now researching this topic in order to incorporate it in my work. Additionally, I made the important choice to choose the confrontational 8k image upscaler. I understood the value of stock photographs, which make it easier to get the desired outcome quickly.
